Hi. I’ve just installed a cover plate on my Aqara Shutter Switch H2 EU, which required me to remove some screws. I assume they’re the same screws as those on the Aqara Wall Outlet H2 EU. However, I can’t say for certain as I don’t have one.
I’d estimate it to be around 4 mm in diameter and 7 mm in length.
Alternatively, you could take the socket with you to the DIY store. If they have a range of screws available, you could test them there and then. However, you should let a member of staff know beforehand, as our DIY store now stocks smart home accessories.
Thank you, my screw was silver, but it looks like it’s a very similar size.
The outlet is already installed and my fridge is plugged into it so naturally I don’t want to leave it unplugged too long Naturally, I could temporarily install some dumb outlet while I look for the screw, but I wanted to avoid doing this, as it’s just the front plate (it’s currently held by the plug)
