Help Shape the Future of Water Leak Detection šŸ’§
Hi everyone!
We’re exploring ideas for a water leak sensor and would love to learn how leaks happen—and how people deal with them—in homes like yours.
The survey takes about 5 minutes to complete. There are no right or wrong answers, so just tell us what you really think.
:point_right: Take the survey here (Closed): Water Leak Sensor Survey
The survey is expected to close on October 16.
Thank you for helping us create products that better meet your needs!
Thanks for soliciting feedback on this :). Matter over thread with direct pairing would be huge :slight_smile:
Done!! Hope it helps to develop a better water leak sensor, providing a better connectivity and stabiility.
Most of the actual sensors suffer fron disconnections.
Filled out. Looking forward what you come up with based on the feedback
I’m using aqara’s leak sensor and ikeaā€s matter over thread
We have Aqara leak sensors in several locations of our home…except in the downstairs bathroom which is the only room we’ve actually had a leak in. Why? Because Lois, our Corgi, treats water leak sensors as chew toys and we have t been able to break that habit. It’s the only one she can get to and the only one that we’ve actually needed lol
Besides using the leak detector in the basement, I use it for garden watering automations and (not so successfully) for rain detection with the native Aqara app, using a raindrops module as a probe extension.
I am not sure if it’s a hardware limitation of the current Leak Sensor, but besides the current options of ā€œLeak Detectedā€ and ā€œWater Recedesā€, it would be nice to see the addition of:
  • ā€œIn Leak(water) Detected Stateā€
  • ā€œRemains in Water Detected state beyond a defined timeā€
  • ā€œRemains with no Water Detection state beyond a defined timeā€
    (Also to have those options available inside the ā€œANDā€ section.)
    In addition, it would be great to have a ā€œDurationā€ option in the 3 dots pop-up menu.
On the Aqara UI, it would also be nice to have more flexibility with custom naming of the card — not just ā€œLeak Detectedā€, because depending on the use case it could be ā€œTank is Fullā€, ā€œDryā€, ā€œEmptyā€, ā€œRainingā€.
Filled the form as well! Great youā€˜re asking the community for their needs again
Done!
Filled the form :+1:
Done! Easily one of the most useful products when paired with the shut off valve.
Done.
I filled out the survey. I previously had three Aqara water sensors in my basement which ran off of Aqara 2K Cameras w/Hub G3 which were located on the first floor above them. They constantly disconnected as the signal was not strong enough. The nature of water sensors is that they will need to communcate through walls and floors.
Done. Thanks for taking us into account!
Already done.
I use 2 water leak detectors. Aqara and Eve.
I use Aqara when it is a particularly small spot, like under a sink in the bathroom. I use eve for something more extensive or difficult to get to, such as running the wire sensor along behind the kitchen cabinets and that it is mains powered.
I have a handful of these in my home. Thankfully haven’t had to use them though
I use the aqara sensor with my water softener; basically, I keep it inside the brine tank where the salt tablets are stored. When the salt runs out, the level drops and the sensor touches the brine, triggering a notification that the tank is empty and needs to be refilled with fresh salt.
Oh I love that idea!!! That’s brilliant, I’m gonna do the same. Thanks!!
