Hey everyone, I wanted to share a positive experience I had with my Hive smart thermostatic radiator valves (TRVs). I recently encountered an issue where the TRVs would take an unusually long time to open after the room temperature dropped slightly below the set target. This resulted in the boiler running for extended periods, which was both inefficient and frustrating.
After some research and experimentation, I stumbled upon a simple yet effective solution using Home Assistant automations. By setting the TRV to boost mode for a few minutes whenever it detects a drop in temperature, the valve fully opens, allowing the radiator to heat up quickly. This has significantly reduced the boiler runtime from around 20 minutes to just 5 minutes!
Here’s how it works:
- Automation Trigger: The automation is triggered when the TRV detects a drop in temperature.
- Boost Mode Activation: Upon triggering, the automation sets the TRV to boost mode for a few minutes.
- Quick Heating: The boost mode ensures the valve fully opens, allowing the radiator to heat up rapidly.
- Efficiency: This reduces the overall time the boiler needs to run, saving energy and improving efficiency.
I’ve implemented this workaround for all my TRVs, and it’s made a world of difference. I’m now considering adding more Hive TRVs to my system thanks to this fix!
If anyone has additional tips or alternative solutions for optimizing TRV performance, I’d love to hear them. Let’s continue to share knowledge and improve our smart home setups together!
Happy automating!
