Home Assistant Aqara Lighting Integration
I’m pleased to announce the release of my Home Assistant Aqara lighting integration for the T1M Ceiling Light, T1 LED Strip and T2 bulbs. It’s still in beta phase (v0.3.0) but has the base features implemented now and is ready for public testing.
Overview
Easily control Aqara lights with RGB dynamic effects, individual segment patterns, gradients, CCT sequences, and state restoration.
Features
  • Aqara App Effect Presets - Quick access to 24 preset effects from the Aqara mobile app
    • 4 T2 Bulb presets (Candlelight, Breath, Colorful, Security)
    • 9 T1M presets (Dinner, Sunset, Autumn, Galaxy, Daydream, Holiday, Party, Meteor, Alert)
    • 7 T1 Strip presets (Rainbow, Heartbeat, Gala, Sea of Flowers, Rhythmic, Exciting, Colorful)
  • Segment Pattern Presets - 12 T1M/T1 Strip segment color patterns from the Aqara app
  • Dynamic RGB Effects - 13 different manual effects including breathing, fading, flowing, chasing, rainbow, and more
  • Effect Dropdown Selector - Easy-to-use UI dropdown showing all available effects and presets
  • RGB Color Pickers - Color picker UI for all services (up to 8 colors for effects, 6 for gradients)
  • Individual Segment Control - Set custom colors for each segment on T1M and T1 Strip lights
  • Smooth Color Gradients - Create color transitions across segments with 2-6 colors
  • Color Block Patterns - Generate evenly spaced or alternating color blocks
  • Flexible Segment Selection - Support for ranges (“1-20”), individual segments, and special selectors (“odd”, “even”)
  • CCT Dynamic Sequences - Create multi-step color temperature and brightness sequences with smooth transitions
  • T1 Strip Variable Length Support - Automatically detects and adapts to T1 Strip’s length (1-10 meters)
  • Light Group Support - All services work with Home Assistant light groups for synchronized multi-light control
  • Auto Turn-On Option - Optionally turn lights on automatically before applying effects or sequences
  • Unspecified Segment Control - Option to turn off segments not included in patterns
  • Automatic Device Discovery - Discovers supported Aqara lights through Zigbee2MQTT
  • Service-Based API - All features accessible via Home Assistant services, automations, and scripts
Usage
All features are available as Home Assistant services. Call these services from automations, scripts, or the Developer Tools.
Requirements
  • Home Assistant 2025.12.0 or newer (older versions not tested)
  • Zigbee2MQTT 2.7.2+ / or ZHA
Full details on the Github page.
New in v.0.4.0
Frontend Panel
A new UI panel has been added to the Home Assistant sidebar for easy access to presets:
  • Sidebar Integration - Access the “Aqara Lighting” panel directly from the Home Assistant sidebar
  • UI Buttons - Interface for managing lights, effects, and sequences
  • Preset Buttons - Access to all effect and sequence presets
  • Built with Lit - Modern, lightweight web component framework for optimal performance
  • More features to be added soon
The panel provides a centralized location for controlling Aqara lights without needing to use the Developer Tools or create automations.
RGB Segment Sequences
Create animated segment patterns with the segment sequence feature:
Key Features:
  • Up to 20 Customizable Steps - Build multi-step sequences
  • Multiple Activation Patterns:
    • Sequential forward/reverse - Segments activate one by one
    • Random - Segments activate in random order
    • Simultaneous - All segments activate at once
  • Pattern Modes:
    • Gradient - Smooth color transitions across segments
    • Blocks (repeat/expand) - Evenly spaced color blocks
    • Individual - Custom color per segment
  • Timing Control:
    • Duration - Time to complete the activation pattern
    • Hold - Time to hold after activation completes
  • Loop Options:
    • Run once, loop X times, or continuous loop
    • Choose to maintain state or turn off when complete
  • Pause and Resume - Control sequence playback mid-execution
New Services:
  • start_segment_sequence - Start an RGB segment sequence
  • stop_segment_sequence - Stop a running sequence
  • pause_segment_sequence - Pause a running sequence
  • resume_segment_sequence - Resume a paused sequence
CCT Sequence Enhancements
The existing CCT sequence feature has been enhanced with pause and resume functionality:
New Services:
  • pause_cct_sequence - Pause a running CCT sequence while maintaining current state
  • resume_cct_sequence - Resume a paused CCT sequence from where it was paused
Pleased to announce v0.5.0, a major feature release that brings frontend visual effect and pattern editors, and a preset management system. This release focuses on enhancing the frontend user experience with intuitive creation tools while maintaining full backend compatibility. Update via HACS, and be sure to hard refresh the browser to clear any cached previous version.
Enhanced Panel UI with Visual Editors
The sidebar panel now includes interactive visual editors for creating custom effects, patterns, and sequences:
  • Effect Editor - Create custom dynamic RGB effects
    • Effect type selector
    • Up to 8 color pickers for effect colors
    • Speed and brightness sliders
    • Segment selector for T1 Strip effects
    • Live preview of effect settings
    • Save as custom preset
  • Segment Pattern Editor - Design custom segment color patterns
    • Visual segment selector showing all available segments
    • Color picker for each segment or range
    • Gradient and block pattern generators
    • Turn off unspecified segments option
  • CCT Sequence Editor - Build multi-step CCT sequences
    • Up to 20 steps with visual timeline
    • Color temperature and brightness sliders for each step
    • Transition and hold duration controls
    • Loop mode and end behavior settings
    • Live step preview
  • RGB Segment Sequence Editor - Create animated segment sequences
    • Up to 20 steps with animation patterns
    • Multiple color modes (gradient, blocks, individual)
    • Activation pattern selector with 8 options (all at once, sequential forward/reverse, random, ping pong, centre out, edges in, paired)
    • Duration and hold controls
    • Loop settings with skip first step option
    • Clear segments before starting option
User Preset System
Create, save, and manage your own custom presets for all feature types:
  • Preset Management - Full CRUD operations for user-created presets
    • Create unlimited custom presets
    • Edit existing presets with full customization
    • Duplicate presets to create variations
    • Delete unwanted presets
  • Supported Preset Types - Save presets for all features
    • Effect presets (dynamic RGB effects with colors and settings)
    • Segment pattern presets (custom segment color arrangements)
    • CCT sequence presets (multi-step color temperature sequences)
    • RGB segment sequence presets (animated segment patterns)
  • Persistent Storage - Presets stored across Home Assistant restarts
    • Automatic save on creation/update/delete
    • UUID-based preset IDs for reliable tracking
    • Timestamps for created and modified dates to allow for sorting
New in v0.6.0 is a Device Config panel which allows you to apply configuration settings to multiple Aqara lights at the same time. Available settings are filtered according to which kind of devices are selected, and only the compatible settings are sent to each device.
For T2 bulbs these include a visual editor for transition curvature with draggable adjustment graph.
Full details of the update are in the changelog.
Wow, this is super cool! Very nice job.
Do you think you’ll ever make it work with ZHA?
Thanks. I have no plans to at the moment unfortunately, support for the lights features would need to be added to ZHA itself first.
Since my last post the integration is now up to v0.11.0, new features include:
  • Segment Zone Naming - Assign custom names to segment zones on each device with a visual grid editor for intuitive zone configuration
  • Device triggers for HA automations - Aqara lighting devices now appear in the Home Assistant automation UI device trigger selector, enabling native trigger-based automations of features
  • Interactive Visual Segment Selection for segment patterns and sequences
  • XY Color Picker Modal - with color history swatches
  • Dynamic SVG preset preview thumbnails - Presets now display dynamically generated SVG thumbnail previews showing the actual color pattern
  • Advanced Gradient Creation - Interpolation mode selector, mirroring and wave easing
  • Per-user preferences with server-side storage - User preferences are stored on the server, persisting across browsers and devices
  • REST API Trigger Endpoint- Trigger presets from external systems such as Node-RED or iOS shortcuts
  • Multiple Zigbee2MQTT Instance Support
  • User Preset Backup and Restore
Many more features and improvements have also been implemented.
It’s also now installable directly through HACS, just search for Aqara Advanced Lighting within the Home Assistant Community Store in your HA iinstallation.
Very nice! it makes me want to install Zigbee2MQTT.
Requirements
  • MQTT integration configured and running
  • Zigbee2MQTT 2.7.2 or newer
Thanks. Unfortunately ZHA or Matter just aren’t capable of such features with the lights.
wow! very nice. And such love to Aqara’s lights. I think you could expand this and see great traction if it were more open, but I understand your interests. Well done.
Thanks. In the long run I may well add support for other manufacturers once I run out of things to do with the Aqara lights I have or if they stop releasing new lights with new features to explore. I really want to get one of the new V1 Sky Mirror ceiling lights to reverse engineer.
It really just grew out my want to add the T2 bulb effects to Home Assistant and then ballooned from there as a fun side project to play around with.
Awesome ! Great job :clap: and so passionated :x2fozabcpx9xrbxmdpseb3_61:
Aqara Advanced Lighting v0.12.0 is now available, the main new feature aimed primarily at T2 bulbs, allowing for the creation of Hue-like dynamic lighting scenes across multiple lights, and comes with 58 built-in dynamic scene presets.
  • Up to 8 colors with XY color pickers and per-color brightness control (1-100%)
  • Transition time (30-3600 seconds) for smooth color changes
  • Hold time (0-3600 seconds) to pause at each color
  • Three distribution modes:
    • Shuffle and rotate - Each light gets a different color, then colors rotate smoothly through all lights along the color wheel
    • Synchronized - All lights transition through the same colors together
    • Random - Each light picks random colors from the palette
  • Transition stagger (0-10 seconds) to create wave effects across lights
  • Loop modes: once, count (1-1000), or continuous
  • End behavior: restore to previous state or maintain last color
  • Static mode option to apply colors once without transitions
  • Home Assistant actions, triggers and conditions for scene automations
  • Works with any RGB light entity, not limited to Aqara devices
Other new features include:
  • Device conditions for all services - These allow for the creation of advanced Home Assistant automations like “At 10pm, only turn on the fan if CCT sequence Goodnight is running on the bedroom lamp”
  • Active Presets Monitoring - real-time monitoring of all active operations, with controls for each displayed in the frontend
  • Favorite presets - Quick access to most-used presets
  • Dynamic preset population - Service action dropdowns now populated with current presets including custom user presets
  • Include-all-lights toggle - Option to include non-Aqara RGB/CCT lights for dynamic scenes and CCT sequences
  • plus numerous other improvements and bug fixes.
Updates are available via HACS in Home Assistant.
I have a ZHA alpha version working now with effects and segment control, it’s using raw Zigbee writes to bypass limitations of ZHA.
With the release of v0.13.0 ZHA is now supported for all features. The integration can also handle dual Z2M/ZHA installations with some light on Z2M, others on ZHA.
ZHA Backend Support
Full ZHA integration alongside Zigbee2MQTT
Use Aqara Advanced Lighting features through the ZHA integration without requiring Zigbee2MQTT
  • Custom zigpy quirks for each supported device type (T2 bulbs, T1M, T1 Strip)
  • Direct Zigbee cluster attribute writes for effects, segment patterns, and segment sequences
Other new features in this release include:
Image Color Extractor
Extract colors from images for dynamic scene presets
  • Upload or link an image to automatically extract a color palette
  • Extracted colors populate directly into the dynamic scene editor
T1 Strip Audio Sync
Frontend controls for T1 Strip music synchronization mode
  • Audio sync toggle, sensitivity, and effect controls in the panel
  • 2 device triggers: music sync enabled, music sync disabled (with sensitivity and audio effect in event data)
  • 1 device condition: music sync is active
Dynamic Scene Color Assignment Override
Override color-to-light assignment when activating scenes
  • Manually assign scene color distribution
  • Brightness activation override for per-scene control
Ignore External Changes Toggle
Prevent external changes from pausing running operations
  • Toggle to ignore external state changes on entities running sequences or scenes
  • Prevents false external pause detection from other automations or manual adjustments
Plus numerous other improvements and bug fixes.
Aqara Advanced Lighting has reached v1.0.0, the first stable release. It includes Home Assistant 2026.3 compatibility, security hardening, a major UI overhaul with native HA components, mobile/touch improvements and added accessibility support, expanded diagnostics, and significant backend refactoring.
Also new:
CCT and segment sequences can now restore lights to their pre-sequence state
  • New “restore state” end behavior for both CCT and segment sequences
  • Captures light state before sequence starts and restores it on completion
  • State capture and restore also now works with cancel and stop-preview buttons across all editors
Software-Interpolated Transitions for T1-Family Devices
T1M and T1 Strip devices don’t fully support hardware transitions, this release adds software interpolation to simulate smoother longer transitions on these devices.
  • Cubic easing (ease_in_out_cubic) for natural-looking transitions
  • Per-device step intervals: T1M minimum 2.0s (hardware smooths between steps), T1 Strip minimum 0.5s
  • Adaptive interval scaling: shorter intervals for quick transitions, longer for extended sequences
  • Interruptible at any sub-step via stop events
  • CCT transitions in both MQTT and ZHA backends
  • XY color transitions in both MQTT and ZHA backends
  • Shared transition_utils.py module used by both backends and the scene manager
  • Falls back to direct application if entity is unavailable
Bug Fixes
  • Fixed CCT sequence not affecting T1 Strips in RGB mode
  • Fixed CCT editor loop count field not showing when loop mode is count
  • Fixed zone selector event leak
  • Fixed start_dynamic_scene service not finding built-in presets
  • Fixed loop_mode value mismatch between frontend editors and backend schema
  • Fix false external-pause triggers during long transitions and holds
Note: For users of Zigbee2MQTT, it is also recommended to update to Z2M v2.9.0+, that release contains optimizations for effect and segment payloads.
Thank you for putting so much work into it!
Gave it a try and works really well! Plus you can include non-Aqara lights as well
Thanks, couldn’t leave out my lamps with E14 bulbs from the scenes!
New release: v1.1.0
What’s New
Version 1.1.0 adds solar and schedule-based adaptive circadian CCT sequences, capability-aware light adaptation for any Home Assistant light, and a new more comprehensive override detection system.
Circadian Adaptive CCT Sequences
  • Schedule steps use fixed times (12:00) or sun-relative times (sunrise+30, sunset-60)
  • Solar timeline maps elevation to time using sinusoidal sun trajectory with real sunrise/sunset positions
  • Automatic interpolation between steps on a 24-hour cycle
  • Dual-track timeline preview showing color temperature and brightness with step markers
Improved support for non-Aqara lights in dynamic scenes and CCT sequences
  • Software transition opt-in for non-Aqara lights via device config panel
  • Capability profiles classify lights as full-color, CCT-only, brightness-only, or on/off-only
  • Service calls adapted at runtime using XY-to-CCT conversion and color temp clamping
Context-based override detection with per-attribute control for solar and schedule sequences
  • Detects overrides from service call data before state changes arrive
  • Context-only detection replaces grace window system
  • Per-attribute change detection with hardware drift tolerance
  • Non-HA drift detection for changes made outside Home Assistant
  • Bare turn-on adaptation fills unspecified attributes with solar/schedule values
  • Per-attribute pause indicators in frontend
Improvements
  • Proactive adaptation: immediate value application on resume and turn-on
  • Per-preset auto-resume delay
  • Turn off light end behavior for dynamic scenes
  • Skip first step in loop for CCT sequences
  • Added Power Nap CCT sequence preset
  • Selective user preset exports
Bug Fixes
  • Loop N Times count field in Scenes tab
  • Signed URL preset export with selective filtering
  • Preset export using signed URL WebSocket command
  • Auth errors on API calls
  • Active presets panel not updating after activation
  • last-half, first-third, last-third keywords to parse_segment_range
  • Segment patterns not restoring off state when stopped
  • Color restore when activating from an off state
