Home key not in wallet on apple watch
I paired the u400 with my iPhone through the home app. A home key was created and is in the wallet app on the phone. The home key is not appearing in the wallet app on my Apple Watch Ultra 3. Anyone experiencing the same and/or have a solution?
Does this help you?
Negative - home app is on watch as is the device. Still nothing th the Apple Watch wallet app. I also restarted both devices and toggled airplane mode. Also, I unpaired the block and repaired it. I feel like I’m banging my head against the wall.
Maybe you have turned off your password/keychain synchronization in iCloud settings? Or one of the devices is not updated to newest iOS/Watch OS
Keychain synchronization on and both the watch and phone are on 26.2.1.
Are both devices signed in to the same iCloud account?
Try charging both devices. If one of the devices is in power-saving mode, it will not sync.
I will charge both devices and see the results. Both devices are on the same iCloud account.
Both devices are charging and nothing happening. I doubt this is the issue as my credit cards are in the wallet. I added a credit card as early as this morning. It appeared without issue.
Solved after the update to 26.3 and performing a network reset. Key is performing the network reset while the home key is in the iPhone wallet. It seemed to force the transfer.
Hi, what do you mean by network reset? I’m in the same boat, the homekit key isn’t coming over to my watch. All devices on iOS 26, and have an apple TV as hub. Thanks!
