Homebridge accessories can help your HomeKit automations
I use Homebridge to bring non-HomeKit devices into Apple’s HomeKit environment but it can also be helpful in your automations because the Virtual Accessories for Homebridge allows you to create virtual devices that can be used to help control your HomeKit automations. These virtual devices can be used like a variable. Another thing I like is the ability to create timers so you don’t have to do the shortcuts since the shortcuts are only accessible directly in the Home app and not available in apps like Controller For HomeKit.
One example is I have an automation that turns off a light when we arrive at home. I don’t want the light to turn off immediately, so I have created a 5 minutes switch timer in Homebridge that is activates via an automation when we arrive and when the timer expires, it turns the light off. The same functionality can be obtained via a Shortcut but I like to use Controller For HomeKit, and as I said earlier, Shortcuts cannot be accessed outside the Home app.
Another thing I did was create a simple switch to act like a variable. I then have an automation that run year round for landscape lights and when it runs, it turns the switch on. I then have a Christmas automation to turn on other lights during that time of year and instead of putting the same timing in that automation, it triggers when the switch is turned on by the landscape automation, so now if I want to change the time of day to turn on lights, I only have to change one automation and the other automation just works.
Nice tip! Homebridge is really useful when integrating many ecosystems together. It has useful plugins that allow to use it with very closed ecosystems. For example I use Homebridge to integrate my Xiaomi humidifiers with Aqara door and window sensors (when a window is open, I want to lower humidity on the humidifier).
I might add that some automations that use a virtual switch as a state indicator/condition can be also automated in Aqara home using “Enable/disable automation”.
For example: I have an FP2 and two automations that were designed with ghost presence issue in mind.
Automation 1: “When presence in the bedroom is detected Then turn on the LED string AND enable automation 2”.
Automation 2: “When presence in bed is detected Then turn on the bed light”.
Those automations are basically very similar to how you would solve this problem in Apple Home (with Homebridge), but instead of “Enable automation 2”, you would use “turn on switch” and then “When presence in bed is detected AND switch is turned on”
