I recently decided to upgrade my Homematic setup and decided to go with the Raspberry Pi CM4 and IOBoard combination. I wanted to share my experience and some tips that might help others who are considering the same setup.
First, I was drawn to the CM4 because of its improved performance compared to older Raspberry Pi models. The higher RAM and processing power were a big plus, especially since I plan to run multiple services like RaspberryMatic and ioBroker on the same device. The eMMC storage is a great improvement over SD cards, and I appreciate the reduced power consumption, which is a big plus for a 24/7 running system.
One thing I found a bit challenging was choosing the right IOBoard. I opted for the Waveshare CM4-IO-BASE-C, which worked well for my needs. It’s important to consider the number of interfaces you need and how they might affect power consumption. I also added a NVME SSD for backups and logs, which has been really handy.
I’d like to share a quick tip: if you’re using GPIO connections, make sure to use stacking headers to avoid any physical issues with the setup. Also, I found that placing the CM4 and IOBoard in a Clear-Box case helped with cable management and kept everything neat.
Overall, I’m really happy with this setup. It’s become the backbone of my smart home system, handling everything from thermostat control to my security cameras. If you’re looking to consolidate your smart home hardware, I’d definitely recommend considering the CM4 and IOBoard combination.
Thanks to everyone in the community for all the helpful resources and support! If anyone has questions or tips, feel free to share—I’d love to hear how others are using this setup.
