Hi everyone,
With energy costs always climbing, I’ve been experimenting with using Aqara devices for smarter energy savings. For example, I set up my smart plug + motion sensor so that my office equipment shuts off if there’s no movement for 30 minutes. It’s surprising how much power that’s saved over time.
I’m curious — how are you all using Aqara for energy efficiency?
• Automations that cut down on “phantom” power use?
• Creative ways of managing heating/cooling with sensors?
• Seasonal setups (like fans in the summer or space heaters in winter)?
Would love to learn from the community and maybe build out a list of the best “Aqara energy hacks.”
@Sudds65 It’s fantastic to hear that you’re leveraging Aqara devices for energy savings! Your setup with the smart plug and motion sensor to reduce phantom power is a great start. To further enhance energy efficiency, here are a few suggestions based on the Aqara ecosystem:
Heating and Cooling Management: The Aqara Floor Heating Thermostat W500 is perfect for managing your heating efficiently. It allows you to set custom temperature buffers, which reduces the frequency of on and off cycles, thus stabilizing the indoor environment and saving energy. If a window is left open, detected via an Aqara Door and Window Sensor, the heating system pauses automatically to avoid energy waste.
Automation with Sensors: You can use the Aqara Motion and Light Sensor P2 to automate lighting based on motion and brightness. For instance, if the brightness exceeds a certain level and the outdoor temperature is high, you can automate your curtains to close, reducing the need for air conditioning.
Seasonal Adjustments: In the summer, you could use the Climate Sensor W100 to monitor indoor conditions and adjust cooling devices accordingly. Although it currently only connects to one thermostat, future updates may allow for broader connectivity.
By integrating these devices and automations, you can create a more energy-efficient home throughout the year. Keep experimenting and sharing your findings with the community—it’s a great way to discover new “Aqara energy hacks”!
@Sudds65 What a great initiative to explore Aqara for energy savings—your smart plug + motion sensor setup for office equipment is a solid hack! It’s amazing how small automations add up over time.
Speaking of energy efficiency, Aqara devices have some built-in features that could inspire more ideas. For example, the Floor Heating Thermostat W500 can reduce heating cycles with custom temperature buffers and pause heating if a window is left open (detected via a door/window sensor), cutting waste . The Panel Hub S1 Plus EU even provides daily/weekly/monthly energy reports for connected devices, helping you spot usage patterns .
Motion sensors like the P2 can also automate lighting based on both motion and brightness—turning lights on only when needed and adjusting color temperature to save energy . And the Door and Window Sensor P2 can trigger thermostats to turn off when a door or window is open, reducing heating/cooling loss .
Would love to hear what others are doing—any creative seasonal setups or “phantom power” hacks? Let’s build that list together!
@Sudds65 Love that you’re leveraging Aqara devices to tackle energy costs—your motion sensor + smart plug setup for office equipment is a solid hack! It’s amazing how small automations add up over time.
Aqara devices do offer built-in features that can boost energy efficiency, too. For example, the Aqara Floor Heating Thermostat W500 lets you set custom temperature buffers to reduce frequent heating cycles, monitors real-time energy use, and even pauses heating if a window is left open (via a door/window sensor) to avoid waste . The Aqara Panel Hub S1 Plus EU provides daily/weekly/monthly energy consumption reports for connected devices, helping you track and optimize usage . Smart plugs (like the US or EU models) support timing control—setting them to auto-shut off when devices aren’t in use is perfect for cutting phantom power .
Your questions hit the nail on the head—automations for phantom power, heating/cooling hacks, and seasonal setups are all great areas. Let’s hear from the community—share your Aqara energy hacks, and let’s build that list together!
@Sudds65 Great to hear you’re already leveraging Aqara devices to cut down on energy use—your motion sensor + smart plug setup for office equipment is a solid hack for reducing phantom power!
Aqara devices do offer some built-in features that can boost energy efficiency, too. For example, the Aqara Floor Heating Thermostat W500 lets you set custom temperature buffers to reduce frequent heating cycles, and it even pauses heating if a window is left open (detected via a door/window sensor) to avoid waste . The Aqara Panel Hub S1 Plus EU also provides daily/weekly/monthly energy consumption reports, which can help identify where to optimize usage . And smart plugs (like the EU or US models) support timing control, so you can automate devices to shut off when not in use—perfect for seasonal setups like space heaters or fans .
Your idea of compiling “Aqara energy hacks” is awesome! Let’s hear from the community—what automations, sensor pairings, or creative setups have you used to save energy? Whether it’s reducing standby power, managing heating/cooling, or seasonal tricks, sharing your tips could help others cut costs too.
Looking forward to seeing the ideas flow!
