As every FP2 user knows, there are sometimes false positive presence detections, aka ghosts. They can come from larger items (e.g. moved furniture or a cardbox) or are just remains of a person moving around.
Is there any quick possibility to delete these ghosts, without a reset or moving around the ghost?
@StefanD False positive detections, often referred to as “ghosts,” can indeed be a bit frustrating. Fortunately, the Aqara FP2 offers some options to manage these without needing to reset the device or physically move the object causing the detection. You can try the following steps:
Delete Targets: You can long-press the human icon in the app and click “Delete Target” to clear these false detections. This method allows you to remove detected “ghosts” manually without a full reset.
Configure Interference Sources: If the false positives are due to stationary objects like furniture, it’s a good idea to mark these areas as “interference sources” in the app settings. This can help the sensor ignore such objects in the future.
Reset to Absence Status: If you experience frequent false alarms, use the “Reset to Absence Status” feature. This clears all current targets in the monitored space, effectively resetting the presence status without needing to perform a full device reset.
These options should help improve the accuracy of your FP2 and minimize those pesky ghost detections. If you have any other tips or experiences, feel free to share them with the community!
@StefanD It’s common to encounter false positive presence detections (or “ghosts”) with the FP2, and there are a few quick ways to address this. First, you can use the “Reset to Absence Status” feature, which clears all targets in the entire space if there are false alarms . Additionally, for false alarms caused by specific interference (like moved furniture or cardboard), you can adjust settings through “False Alarm Management” to account for these elements while removing the target . Have you tried these methods before? Feel free to share your experience with the community!
Sorry, aber mit diesen KI-Antworten kann ich nichts anfangen.
Eine solche Funktion ist in der App nicht auffindbar.
Auch diese Funktion existiert nicht.
@StefanD Es tut uns leid, dass die vorgeschlagenen Lösungen nicht zu Ihrer Zufriedenheit funktioniert haben und Sie die genannten Funktionen nicht finden können. Nach den verfügbaren Informationen verfügt der Presence Sensor FP2 über eine Funktion zum “Reset absence status” , die theoretisch dazu beitragen kann, fehlerhafte Anwesenheitsmeldungen zu bereinigen. Leider enthalten die aktuellen Referenzinformationen keine genauen Schritte zur Aktivierung dieser Funktion in der App.
Zur Funktion “False Alarm Management” liegen uns derzeit keine entsprechenden Informationen vor. Wenn Sie weitere Schwierigkeiten haben, empfehlen wir Ihnen, sich an den Kundenservice zu wenden – entweder über die Aqara Home App (Profil > Hilfe & Feedback > Kundenservice) oder über den Link, um ein Ticket zu erstellen.
Vielleicht haben andere Community-Mitglieder ähnliche Erfahrungen gemacht – wir freuen uns, wenn Sie weitere Einblicke oder Lösungsansätze teilen!
@admin1 How can I stop or ignore answers from this bot?
