A bedroom example in another discussion showed a tricky edge case: someone standing near the edge of a bed zone made the light switch on and off, even though the room was occupied. Before letting a zone turn a lamp off, I would log zone transitions alongside whole-room presence during normal use, look for brief bounces near furniture or doorways, and test whether a short delay or a whole-room-vacant condition avoids false offs.
How do you validate zone placement and timeouts before enabling a lighting rule? What observations tell you the rule is reliable enough for the people using the room?
I use the map of FP2 / FP400 and check my movements in the selected areas… if it seems alright , I set and activate the automation. Sometimes it needs some fine adjustments and make the area bigger or smaller . Depends also how well the sensor is placed
Checking the FP2/FP400 map while moving around is a useful first pass. When you enlarge a zone to catch someone standing near its edge, do you also check whether walking past the doorway starts triggering it? I would compare both cases before changing the timeout, so a delay does not simply hide a misplaced boundary.
Well, sure! Sometimes it really needs little more fine tuning- and also the height of the sensor can make big changes!
The entrance are is sometimes really tricky- I try to avoid setting areas directly at the entrance areas ( if possible of course)
It’s definitely necessary to mark exit and entrance areas! But it can be difficult sometimes with the right position to the FP sensor ! If you have a direct sight position from sensor to entrance it works great ! But if you have more such areas and can’t make it straight to entrance/exit , it can be hard for the sensor to work properly
Ah, I think I see what you mean. Since the sensor can’t see into my fairly large room, I simply marked the entire side leading to the open space as an “Exits and Entrances” area. Incidentally, areas marked as “Exits and Entrances” can overlap with normal zones (a square on the map can be in one zone and an entrance/exit at the same time).
