I actually had a very similar issue yesterday: an LED light strip kept turning on sporadically without anyone deliberately triggering it.
When troubleshooting something like this, the first step is always to narrow down the scope.
Start by asking yourself what changed: Were there any updates? Were scenes or automations modified? If so, start digging there and temporarily disable those scenes or automations to see if the problem disappears. And, of course, check your traces and log files if they are available.
In my case, I had recently updated both Home Assistant and the LED strip’s firmware. That narrowed things down considerably, though you can never completely rule out external factors. Home Assistant’s revamped Activity Dashboard is a huge help here because it reveals what triggered an event, but unfortunately, it didn’t yield any clues this time.
If you run multiple ecosystems in parallel like I do (Apple Home, Aqara Home, and Home Assistant), you can systematically isolate where the fault lies through process of elimination:
- I shut down the Home Assistant server, but the problem persisted, which ruled out the Home Assistant update as the cause.
- I unplugged all Aqara hubs that execute automations, yet nothing changed.
- I disconnected the Apple Home hubs as well, but the strip still kept turning on.
That confirmed none of the smart home platforms were causing it.
At that point, the issue had to be tied directly to the LED strip’s firmware update. Naturally, I had already tried power-cycling it, but a reboot changed nothing. I had previously bought a separate hardware remote for the strip, which I kept using to switch the light back off whenever it turned on by itself. After turning it off once more, I stepped away for a moment. When I walked back into the room, the light popped on the exact second I stepped in front of the remote.
Coincidence? Not quite.
Right then, it hit me: the remote actually has a built-in motion sensor feature that had never worked previously. The firmware update had clearly fixed communication with the remote, quietly bringing the motion detection to life.
The takeaway? If you test an experimental or broken feature and it doesn’t work, disable it right away. Otherwise, it might surprise you later.
