How has FP400 been for you?
It’s about 1 week away since I’ve gotten my FP400, throughout this period of time I’ve change multiple places and reconfigured the settings to achieve the best result possible.
TL;DR
Pro:
It’s works pretty great, almost perfect when you’re the only person using. It catch your presence and absence nicely from zone to zone, rarely mis-recognize you as interference source.
Cons: (here we go)
  • Forget about the ability to recognize 10 person, FP400 already has issue when checking 2 person in the same room. When you walk pass the other person, immediately it became 1 person and you’re gone from the map.
  • At many times, it recognize person as interference source, regardless far (4-5 meter) or near (2 meter). It’s crazy when we are 2 meter near and I’m being recognize as interference source. No matter how many times I’ve re-run the AI Spatial Learning, it results the same.
  • It has issue differentiating little human (toddler) and pets. It has been recognizing my little human as pet (showing the paw sign). He basically has no capability to show his presence at any zone to trigger any light event. Sad. For the record, this is when I do ceiling mounting at height of ~210cm where my toddler is ~90cm.
  • The list goes on…
So, what’s your experience? How have you found your “best spot” to install and what’s the best configuration you configured that work best for you? I’d love to hear from the community.
Mine has been great once I got Thread up and going. Granted, I don’t normally have ten people in my bedroom and I don’t have pets or small children.
Seems like you’re the only person in the room / zones. That’s what I’ve mentioned too, it works great for 1 person, but this should not be the benchmark.
Yeah, I agree with that. I have seen four people be tracked at once successfully but that was for a pretty short time period. I just don’t have more data. I’m sure others will mention how the FP400 has been for them.
Do you have any updates on this? I mean, is it performing any better?
Sadly no.
I had 3 zones setup, and I gave up 2 zones due to the poor detection. Remaining 1 zone (surprisingly that’s the furthest I have), and it’s work well so far.
Let me know how it has been for you
For the record, I found this docs quite some time back. Not sure if it’s useful for anyone. Enjoy reading!
Well mine since day one of trial has working perfectly without any issue and sure my bathroom is not so big but there are 2 zones I made beside the main one and works perfectly no issue with.i am using it on thread mode
I’ve already written a long post about my own experiences with the FP400.
This is my living/kitchen space. I divide the space into two zones. You can see my attempts to get rid of the problem areas by either removing parts of the room, by flagging areas where the ghosts accumulate, and by aggressively labelling a quarter of the space as exit/interference.
I am now in the habit of running the AI Spacial Learning at bedtime to clear out all the ghost humans & dogs so that overnight automatic lighting still works for our 2 young adults with additional needs who have irregular sleep patterns.
The FP400 just doesn’t work for this space. Likely causes include a gigantic metal fridge on the left side and 2 windows opposite on the right. The house construction is 1960s cinder/clinker block, so nothing but hard impenetrable walls. The location of the sensor works at it’s best where it is.
I’m going back to IR for triggering the kitchen end and abandoning other presence automations for the living area.
I have ideas to monitor an outside yard with the FP400. It’ll either be mounted against the glass of one of those windows or I’ll put it outside in a suitable weatherproof enclosure.
My experience has been mixed.
Though in general it’s been very good, it’s the moment that it does’t work well that splits opinions.
At start I had 1-2 incidents. It would go well for a couple of days and then it had an issue again.
Then gradually it started getting worse. With the last 24 hours resulting in multiple lengthy detection issues.
After doing the spacial learning it cleared but having Home Assistant as my main platform it’s a bit annoying as a step to do.
Sometimes it detects my WFH chair as presence. Other times it loses my presence on the couch, which I understand as I’m not facing it.
It picks me up well at the Exit/Enterance despite the distance.
But when I stand still in the couch area for 1 minute detection clears.
