Hi all, I wanted to share my journey in automating my chicken coop door. It’s been a fun project, and I hope my experience can help others who might be tackling similar challenges. Here’s my story:
I’ve always wanted to automate my chicken coop door to open automatically when the multisensor detects it’s closed. The goal was to ensure the door opens just enough for the chickens to come out but stays closed during the day. However, I encountered a snag: as soon as the sensor opened, the power to the outlet would cut off, leaving the door only partially open. This was frustrating, especially since I wanted the door to stay open for exactly 2 minutes each morning.
After some research, I found a solution using a simple automation script. Here’s the code I used:
python
def contactHandler(evt):
state.contact1Now = evt.value
def appTouch(evt):
if (state.contact1Now == ‘closed’):
switch1.on()
def fiveMinuteDelay = 60 * 2
runIn(fiveMinuteDelay, turnOffSwitch)
def turnOffSwitch():
switch1.off()
This script ensures the door stays open for exactly 2 minutes, giving the chickens enough time to exit without the door fully opening. I also made sure to test the system thoroughly to ensure it works reliably.
Here’s what I learned:
- Always test your automation scripts in a controlled environment before implementing them.
- Pay attention to the timing of your delays to ensure the automation behaves as expected.
- Don’t hesitate to reach out to the community for advice if you encounter unexpected issues.
I’m thrilled with how this project turned out, and I can’t wait to see how others might improve upon this setup. If anyone has suggestions or alternative approaches, I’d love to hear them!
Cheers,
