I’ve recently completed a fun DIY project using my Govee lights, and I wanted to share how I installed them behind my granite wall. It’s a great way to add some ambiance to your space without drilling holes or damaging your walls. Here’s how I did it!
First, I measured the area where I wanted to place the lights. I decided on a specific pattern that would complement the existing decor. I used a level to ensure everything was straight and evenly spaced. Once I had the layout planned, I carefully placed the lights using a strong adhesive that’s safe for granite surfaces.
One thing I learned is to test the adhesive on a small, inconspicuous area first. This way, I could make sure it wouldn’t leave any residue or damage the surface. After confirming it was safe, I applied the adhesive and carefully pressed the lights into place.
To power the lights, I used a discreet power strip that I mounted behind the wall. This keeps everything looking clean and organized. I also made sure the power strip was easily accessible in case I need to adjust the lights in the future.
For those wondering about the wiring, I opted for a simple setup. I used a power injector that connects directly to the Govee lights, eliminating the need for additional wiring or complicated configurations. This made the installation process much smoother and less intimidating.
I also created a short YouTube video documenting the entire process. It’s a visual guide that might help others who are considering a similar project. You can check it out here: YouTube Video Link.
Overall, I’m really happy with how it turned out. The lights add a cozy and welcoming feel to the room, and they’re easy to control using my smartphone. Plus, the installation was much simpler than I initially thought. If you’re looking for a weekend project, I highly recommend giving this a try!
If anyone has questions or needs advice on their own Govee light installation, feel free to reach out. I’d be happy to help!
