How I Set Up My Smart Lighting Automation
As a new homeowner, I’ve been diving into the world of smart home automation to make my life easier and more comfortable. One of the first things I wanted to tackle was automating my lighting system. I’ve always been a bit forgetful, and I often find myself leaving lights on when I leave the house, which is both inconvenient and wasteful. So, I decided to set up an automation that would turn off my lights when I leave the house.
To start, I did a bit of research and found that Home Assistant has some great tools for setting up automations. I decided to use the built-in automation editor to create a rule that would trigger when I leave the house. I knew I had a smart lock on my front door, so I decided to use that as the trigger. I set up the automation to turn off all the lights in the house when I lock the door.
However, I quickly realized that this wasn’t quite what I wanted. There were times when I would lock the door but still be home, and I didn’t want the lights to turn off in those cases. So, I decided to add a condition to the automation. I set it up so that the lights would only turn off if I locked the door and was not home. This required me to use the geolocation feature in Home Assistant, which tracks my phone’s location. I set it up so that if I’m not within a certain distance from my house, the lights will turn off when I lock the door.
This worked perfectly, but I wanted to take it a step further. I decided to set up a routine where the lights would dim gradually when I’m about to leave the house. This way, I wouldn’t be in the dark when I unlock the door later. I used the built-in scenes feature in Home Assistant to create a dimming routine that would activate when I lock the door. This added a nice touch to my automation, making it feel more polished.
Overall, setting up this automation has been a great experience. It’s made my life easier and has saved me some money on my electricity bill. I highly recommend exploring Home Assistant’s automation features to anyone looking to enhance their smart home setup. If you have any questions or tips, feel free to share them below!
