We have U300 locks around the home but only 1 M3 hub. The issue is some of the locks drop their matter connection frequently. I thought once the lock was paired with the hub the connection was maintained over IP6. In practice though it appears it maintains by a Bluetooth connection and I have to install hubs near all locks.
Is that true? And if so what’s the cheapest way to deploy multiple hubs?
If not what’s the right way to keep the locks in sync with the hub?
Thanks
Steve
Normally one should enough but if the connection is too bad , it’s worth to extend the connection by M100
Hi there.you could also use some thread smart plugs in between to make thread network more stable.you do not need hubs for that matter as thread border routers like Aqara power plug H2 if you are on EU are just fine.or any other thread smart plugs witch you can connect them via M3 .
All what you need is thread extender (light, plug) any device is directly connected to electricity so that can be the router for thread mesh network, any device powered by battery is counted as an end-point, and if it far away from the hub it drops connection but if you have a bulb or plug in the middle that will make the mesh network stronger
