Hey everyone! I wanted to share a quick guide on how to automate your coffee machine using Home Assistant. I’ve been using this setup for a while now, and it’s been a lifesaver for my morning routine. Here’s how it works:
Step 1: Set Up the Smart Plug
First, you’ll need a smart plug to control your coffee machine. I recommend using a reliable brand like TP-Link or Shelly. Plug your coffee machine into the smart plug and make sure it’s connected to your home network.
Step 2: Create an Automation in Home Assistant
Open Home Assistant and navigate to the Automation section. Create a new automation and set the trigger to a specific time, say 7:00 AM. For the action, choose to turn on the smart plug connected to your coffee machine. You can also add a delay if you want the coffee to start brewing a few minutes after the machine turns on.
Step 3: Fine-Tune with Sensors (Optional)
If you want to get even more precise, you can add a motion sensor or a light sensor to the mix. For example, if you’re not always home at the same time, you can set the automation to trigger when you’re near your home or when it gets dark outside.
Step 4: Test and Adjust
Before you go to bed, make sure to test the automation. Turn off the coffee machine and let the automation run its course. If everything works as expected, you’re all set! If not, check the logs in Home Assistant to troubleshoot any issues.
Tips for Success
- Use a programmable coffee machine that starts brewing when it turns on.
- If your coffee machine has a built-in timer, you can combine it with the smart plug for even more flexibility.
- Consider adding a notification in Home Assistant to let you know when the coffee is ready.
This setup has been a game-changer for me, and I hope it helps you too! Let me know if you have any questions or if you’ve found a better way to automate your coffee routine. Cheers! ![]()
