I was just playing with the privacy mask settings for my G410 but mis-understood how it works, and ended up masking out the wrong area. Unfortunately, I can’t find a way to undo that mask, or remove all masks completely. Help.
Hello, click on the shaded area again to remove this drawing.
I tried that. It appears that these three black squares that appear on the screen aren’t actually masked areas, as I can add three more, which can be removed by tapping them, as expected. The doorbell is currently running on battery, but I’ll be switching to hardwire so I’ll reset it then and see if that resolves it.
Edit to add that after adding three masks, removing them, then saving, that the three “stuck” black squares no longer appear.
