How to Create a Curved Progress Bar in Watch Face Studio
I’ve been experimenting with creating custom watch faces, and one feature I really wanted to add was a curved progress bar. At first, I wasn’t sure how to achieve this since the Watch Face Studio interface didn’t seem to offer a direct option for curvature. After some trial and error, I figured out a workaround that works perfectly!
Here’s what I did:
  1. Start with a Circular Progress Bar: I began by selecting a standard circular progress bar from the available options. This gave me a solid foundation to work with.
  2. Adjust the Angular Distance: The key to creating the curve was adjusting the angular distance setting. By tweaking this value, I could control how much of the circle the progress bar would occupy, effectively shaping it into a curve.
  3. Fine-Tune the Curvature: If the progress bar looked a bit squashed or stretched, I found that unlocking the aspect ratio in the curving section allowed me to adjust the width and height independently. This helped in achieving a smooth, natural curve.
  4. Test and Refine: I tested different angular distances and aspect ratios to see how they affected the appearance of the progress bar. It was a matter of finding the right balance to get the exact curvature I wanted.
This method worked like a charm, and I was thrilled with the result! The curved progress bar adds a unique touch to my custom watch face, making it both functional and visually appealing. If you’re looking to add a similar feature to your watch face, I highly recommend giving this technique a try. It’s a great way to customize your device and make it truly your own!
