Hi everyone, I’m excited to share a helpful tip that I recently discovered while working with the Lovelace UI in Home Assistant. If you’re like me, you love the sleek and customizable interface that Lovelace offers, and you’re always looking for ways to make your setup even more functional. Today, I want to talk about how I created a button in Lovelace that allows me to manually trigger a Speedtest update. This was a feature I really missed when I switched from the Classic UI to Lovelace, and I’m thrilled to have found a solution!
Why Update Speedtest Manually?
For those who aren’t familiar, the Speedtest sensor in Home Assistant periodically checks your internet connection and updates metrics like download and upload speeds. While it’s great that this happens automatically, there are times when you might want to manually trigger an update. For example, if you’re experiencing connectivity issues, you might want to run a test immediately to see if your speeds have dropped. This is where having a dedicated button in Lovelace comes in handy.
The Classic UI vs. Lovelace
In the Classic UI, there was a straightforward way to create a button that invoked the sensor.update_speedtest service. However, when I made the switch to Lovelace, I was a bit puzzled about how to achieve the same functionality. I knew Lovelace was powerful, but I needed to figure out the right way to set this up without using any markdown or images, as per the community guidelines.
The Solution: Using the Button Card
After some research and experimentation, I discovered that Lovelace actually makes it quite simple to create a button that triggers a service call. The key is to use the Button Card. This card allows you to define actions that occur when the button is clicked, including calling services. Here’s how I set it up:
Open Lovelace Configuration: Start by accessing your Lovelace configuration. This can typically be done by clicking the gear icon in the top-right corner of the UI and selecting ‘Configuration’.
Add a New Card: Navigate to the dashboard where you want to add the button and click the ‘+’ icon to add a new card.
Select the Button Card: From the list of available cards, choose the ‘Button’ card.
Configure the Button: In the button’s configuration, you’ll need to specify the service you want to call. In this case, it’s
sensor.update_speedtest. You can do this by adding the following to the button’s settings:service: sensor.update_speedtest
Customize the Button: To make it visually appealing, I added a custom icon (such as
mdi:speedometer) and changed the button’s color to match my theme. This makes the button both functional and aesthetically pleasing. -
Save and Test: Once you’ve configured the button, save your changes and return to your dashboard. Click the button to test it out. You should see the Speedtest sensor update almost immediately.
Tips and Tricks
- Automation Integration: If you want to take this a step further, you could integrate this button into an automation. For example, you might want to trigger a notification after the Speedtest runs to let you know the results. This would involve setting up a condition based on the Speedtest sensor and then defining the notification action.
- Customizing the Look: Don’t be afraid to experiment with different icons and colors to make the button fit seamlessly into your Lovelace setup. There are plenty of resources available online for finding the perfect icons and color schemes.
- Sharing Your Setup: If you come up with a particularly clever or visually appealing way to implement this button, consider sharing it with the community. Others might appreciate your creativity and learn something new!
Conclusion
I hope this guide has been helpful for anyone looking to add a Speedtest update button to their Lovelace setup. It’s a small but incredibly useful addition that enhances the functionality of your Home Assistant installation. If you have any questions or tips of your own, feel free to share them in the comments below. Let’s continue to support each other and make the most out of our smart home setups!
Happy automating!
