How to Deploy Matter Devices in an Old Apartment? Need Some Pro Tips!
Hey folks! Just moved into this charming but ancient apartment (built in the 80s, lol), and I’m determined to smarten it up with Matter devices. Problem is, the walls are thicker than my patience, and the Wi-Fi’s spotty at best.
Has anyone pulled off a Matter setup in a similar dinosaur-era building? I’m especially stuck on:
  1. Router placement—do I need a mesh system, or will a single beefy one do?
  2. Thread vs. Wi-Fi for Matter—what’s been more reliable for you in a concrete jungle?
  3. Any sneaky workarounds for rooms where signals go to die?
Bonus headache: My landlord won’t let me drill holes for wiring. facepalm
Would love to hear your hacks or even “what NOT to do” stories. Thanks in advance—y’all are my last hope before I revert to yelling at light switches like a caveman.
(PS: If you’ve got specific device recs that play nice with old buildings, throw ’em at me!)
@NestNerd Hey there! Tackling a smart home setup in an older apartment can definitely be a challenge, but it’s totally doable with the right approach and tools. Here are some tips that might help you out:
  1. Router Placement and Mesh Systems: In a building with thick walls, a single powerful router might not suffice. A mesh Wi-Fi system could be your best bet, as it uses multiple nodes to create a more extensive and reliable coverage area. This setup can help alleviate those Wi-Fi dead zones without the need for additional wiring.
  2. Thread vs. Wi-Fi for Matter Devices: Both have their pros and cons, but in environments with challenging Wi-Fi conditions, Thread can be more reliable. Thread networks create a mesh that can bypass obstacles that might interfere with Wi-Fi signals. Devices like the Aqara Hub M100 act as a Thread Border Router, enhancing your network’s stability and reach.
  3. Workarounds for Weak Signal Areas: Consider using devices that support both Zigbee and Thread, like the Aqara Hub M100, to bridge connectivity gaps. Additionally, placing mesh nodes strategically in rooms with poor signals can help. For a non-drilling solution, adhesive hooks or command strips can be used to mount devices without damaging walls.
  4. Device Recommendations: Look for dual-protocol hubs that support both Zigbee and Thread, as these can offer more flexibility in older buildings. The Aqara Hub M100 is a great option, as it supports both protocols and acts as a Matter Bridge, allowing integration with various ecosystems like Apple Home, Amazon Alexa, and Google Home.
It’s all about finding the right balance and placement to make the most of the technology available. If you’ve got more specific questions or need further assistance, feel free to reach out. Good luck with your setup, and don’t hesitate to share your progress and any tips you discover along the way!
