I recently stumbled upon an interesting challenge while trying to display a list of all known devices in my network. Under the ‘States’ section, I found a group called ‘group.all_devices’ that supposedly contains all the devices at home. However, when I attempted to add this group to a view, it didn’t show up as expected. Here’s what I did and what I discovered:
First, I checked my configuration file to ensure everything was set up correctly. My view was configured like this:
yaml
group: device_tracker_view:
name: Devices on the network
view: yes
icon: mdi:wifi
entities:
- group.all_devices
The configuration seemed fine, but the group still didn’t display. I wondered if there was something I was missing or if the group itself had issues. To troubleshoot, I reviewed the ‘States’ section and confirmed that ‘group.all_devices’ indeed contained the expected devices. However, adding it to the view remained unsuccessful.
This led me to explore alternative methods for listing devices. I heard that using cards or custom components could be a solution, but I wasn’t entirely sure how to implement them. I decided to look up some documentation and found a helpful guide on creating custom components. It turns out that custom components can be used to display device lists in a more user-friendly way.
Another thought crossed my mind: could it be a permissions issue? I revisited my view settings and double-checked that all configurations were correct. Everything seemed in order, so I moved on to testing different approaches.
In the end, I discovered that while the initial method didn’t work as intended, there are alternative ways to achieve the desired outcome. I’m now considering integrating a custom component to display my device list effectively. This experience taught me the importance of exploring multiple solutions when facing a challenge in my smart home setup.
If anyone has successfully implemented a similar solution or has tips on how to proceed, I’d love to hear from you!
