Hello,
Other than the switches with neutro, what other devices can I use to extend the signal across the house?
Thank you
Hello,
Thank you
More or less every zigbee device with a plug, i use ikea traffri extenders, but an aqara plug (or ikea plug) will also extend the range.
Do you meant does not matter the brand?
Any brand that supports the zigbee standard should work. I have several different brands mixed and no problems
That is great! ![]()
Yes, mostly any Zigbee device on power is a router. But be careful: some older Aqara battery sensors don’t like third-party routers. They connect, work a few days, then they drop and you need to pair them again. If that happens, use Aqara routers near those sensors: a smart plug, a wall switch with neutral, or a T1 LED strip.
Also, don’t put all the routers next to the hub. Put them between the hub and the sensors that are far, that’s where they help.
