How to Fix Intermittent Flashes on Govee Smart LED Rope
Hi everyone, I wanted to share a solution to a problem I encountered with my Govee smart LED rope. If you’ve ever experienced intermittent bright flashes on your rope, which can disrupt the intended lighting effects, here’s how I resolved it.
The Problem
I noticed that my Govee rope would occasionally flash bright white or green lights, especially at the beginning of the rope. This issue occurred regardless of the brightness setting and whether I was using Bluetooth or Wi-Fi control. It was quite frustrating, especially since it didn’t happen consistently, making it hard to diagnose.
The Solution
After some experimentation, I discovered that resetting the rope fixed the issue. Here’s how you can do it:
  1. Press and hold the power button on the rope.
  2. While holding the power button, quickly press the mode button repeatedly (around 5-7 times).
  3. The rope should go through its reset cycle, and the problem should be resolved.
Additional Tips
  • Ensure the rope is stationary during use, as constant flexing might contribute to the issue.
  • Check if the problem persists across different devices and control methods (Bluetooth vs. Wi-Fi).
  • If the issue recurs, unplugging the rope for a minute before plugging it back in can sometimes help.
I hope this solution helps anyone else experiencing similar issues with their Govee smart LED rope. It’s always a relief to get that perfect lighting effect without unexpected flashes! Let me know if you have any questions or other solutions you’ve found.
Best regards,
