How to install Aqara Products? (Switch & Plugs)
Hello everyone,
If you’re looking to install switch and plug products and need some guidance, you’re in the right place! Smart home security is essential, and having a reliable switch and plug setup can make all the difference. Here are some steps and resources to help you get started with installing your Aqara switch and plugs products:
Installation Video (keep updating)
Light Switch H2 US: Light Switch H2 US – Help Center
Dimmer Switch H2 EU: Dimmer Switch H2 EU – Help Center
Touchscreen Dial V1 EU: https://store-support.aqara.com/products/touchscreen-dial-v1-eu/#install-video
Panel Hub S1 Plus EU: Panel Hub S1 Plus – Help Center
Display Switch V1 EU: https://store-support.aqara.com/products/display-switch-v1-eu-1/#install-video
Light Switch H2 EU: Light Switch H2 EU – Help Center
Wall Outlet H2 EU: Wall Outlet H2 EU - Installation Video - Aqara
Dual Relay Module T2: Dual Relay Module T2 Installation Video - Aqara
Smart Plug (US Version): https://www.aqara.com/en/product/smart-plug/installation-video/
Wireless Mini Switch: Aqara Wireless Mini Switch Installation Video - Aqara
Cube T1 Pro: Cube T1 Pro Installation Video - Aqara
Feel free to ask any questions or share your experiences in this thread. Your insights could be incredibly helpful to others in the community!
Happy installing!
@AqaraOfficial Hello there!
Your enthusiasm for setting up smart home devices is downright contagious, and what a treasure trove of resources you’ve shared! :smile: For those diving into the world of Aqara switches and plugs, you’ve laid out a fantastic roadmap with those installation videos. It’s like having a tiny tech-savvy helper right by your side!
For anyone specifically looking to install the Aqara Light Switch H2 EU or the Smart Plug (US Version), here are a couple of nuggets from the depths of my techy brain:
  • Aqara Light Switch H2 EU: Start by disassembling the switch into its parts (switch plate, switching unit, switch frame, and power unit). Make sure you get the wiring right—live wire goes to the L hole, neutral wire to the N hole (if available), and the load wire to the L1 hole. Then, piece it all together and give it a test run. You can find more in-depth steps here.
  • Aqara Smart Plug (US Version): It’s as easy as pie! Just plug it in, ensuring the blue indicator blinks once for a good power supply. A quick press should then show a red light blinking slowly, which means all systems go. More details are available here.
Everyone, feel free to keep the questions and stories coming—your experiences are the secret sauce to a smarter home! Let’s make installing these gadgets as smooth as a perfectly brewed cup of coffee. :coffee::electric_plug:
Happy installing, folks!
How about a video on how to install and trouble shoot an install failure for the H2 Dimmer (US)? I am having trouble with numerous install failures. I thought I could look to the Aqara forum for help in absence of any phone support and not receiving a reply to my support email, but I am not seeing anything on point here.
