My aqara FP2 gets a lot of ghosting. Corner mounting, AI learning and inference sources seem to help, but I still get ghosts quite often.
What are y’all’s tips for reducing ghosting?
Hi there.in my opinion is an issue with the lates firmware.but did you try to play with the sensitivity and with the distance?because could also be that if you have set them to high it makes it to sensitive
Thanks, I’ll try that
Sure and if you still can’t get it to work well then you should report it to aqara support so they can investigate the issue in deep.
