Hi everyone, I’m excited to share my recent project where I set up a video doorbell with two-way audio without needing a phone app. This was a bit of a challenge, but I managed to find a solution that works perfectly for my setup. I wanted to share my experience in case anyone else is looking to do something similar!
The Challenge
I’ve always been a bit hesitant about video doorbells because most of them require a phone app to communicate with visitors. Since I often keep my phone on silent or in another room, I wanted a way to talk back to visitors without having to grab my phone. After some research, I found that not all video doorbells support two-way audio through a web portal, which was a bit frustrating.
The Solution
After some digging, I discovered that certain brands like Arlo, EZVIZ, and Google Nest do support two-way audio through their web portals. This means I can communicate with visitors directly from my computer or any web browser without needing to install an app. I decided to go with the Arlo Video Doorbell since it had the best reviews and compatibility with my existing security system.
The Setup Process
Installation: The installation was straightforward. I followed the instructions in the manual and had it up and running in about 30 minutes. The most challenging part was wiring it correctly, but the step-by-step guide made it manageable.
Configuration: Once installed, I set it up on the Arlo website. I was impressed by how user-friendly the interface was. I could easily customize settings, adjust the camera angle, and even set up motion detection alerts.
Two-Way Audio: The best part was enabling the two-way audio feature. I simply logged into the Arlo website, navigated to the settings, and turned on the two-way audio option. Now, whenever someone presses the doorbell, I get a notification on my computer, and I can talk back directly from my browser!
Tips for Others
If you’re considering a video doorbell with two-way audio, here are a few tips:
- Research Compatibility: Not all video doorbells support two-way audio through a web portal, so make sure to check this feature before purchasing.
- Check Browser Support: Ensure your browser supports the necessary technologies for two-way audio to work smoothly.
- Test the Audio: Before finalizing your setup, test the audio to make sure it’s working correctly. This will save you time in case there are any issues.
Conclusion
Setting up a video doorbell with two-way audio has been a game-changer for me. It’s not only convenient but also adds an extra layer of security to my home. I hope this guide helps anyone else looking to achieve the same setup. If you have any questions or need advice, feel free to ask!
Happy smart home building! ![]()
