How to Set Up an Automation for Lights to Turn Off After 3 Hours of No Movement
I’ve always been fascinated by how smart home technology can make our lives more convenient and energy-efficient. Recently, I decided to set up an automation in my home that would turn off the lights in a room if there was no movement detected for three hours. It’s a simple yet effective way to save energy and ensure that lights aren’t left on unnecessarily.
Here’s how I did it:
  1. Identify the Devices: I started by identifying the motion sensor and the light switch I wanted to automate. In my case, I used a motion sensor in the living room connected to a smart light switch.
  2. Set Up the Automation: I opened the Home Assistant interface and navigated to the automation section. I created a new automation rule that would trigger when the motion sensor detected no movement for three consecutive hours.
  3. Configure the Trigger and Action: The trigger was set to activate when the motion sensor remained inactive for 180 minutes (3 hours). The action was to turn off the connected light switch. I made sure to test the automation by simulating the absence of movement to ensure it worked as intended.
  4. Testing and Fine-Tuning: After setting up the automation, I tested it by leaving the room and waiting for three hours. The lights turned off automatically, which was exactly what I wanted. I also adjusted the sensitivity of the motion sensor to ensure it wasn’t too sensitive or too slow to detect movement.
This automation has been a great addition to my smart home setup. It not only helps conserve energy but also adds a layer of convenience. I encourage anyone interested in smart home automation to give this a try—it’s a straightforward project with significant benefits.
