How to Synchronize Volume Controls Across Multiple Devices in Home Assistant
Hey everyone, I’ve been exploring how to create a seamless media experience in my smart home, and I thought I’d share my journey and findings with you. One challenge I encountered was getting the volume controls of my living room TV and its connected Android TV box to work in harmony within Home Assistant. Here’s how I tackled it and how you can too!
The Scenario
I have a TV paired with an Android TV box, and while the TV’s DLNA feature allows easy volume control from Home Assistant, the remote setup was initially tricky. My parents use the remote to control the TV volume, and I didn’t want to change their habits. So, I aimed to link the TV’s default Home Assistant card volume controls to the DLNA entity’s controls.
The Solution
After some research, I discovered that automations could bridge this gap. The idea was simple: whenever I adjust the volume on the TV’s default card, it should also adjust the DLNA entity’s volume. Here’s how I set it up:
  1. Identify the Entities: First, I made sure I knew the entity IDs for both the TV and the DLNA device.
  2. Create the Automation: In the automation editor, I set the trigger to be when the TV’s volume changes. The action then updates the DLNA entity’s volume to match.
Here’s a snippet of the automation configuration:
yaml
automation:
alias: “Sync TV Volume with DLNA”
trigger:
platform: state
entity_id: media_player.living_room_tv
action:
service: media_player.volume_set
data:
entity_id: media_player.dlna_device
volume_level: ‘{{ trigger.to_state.attributes.volume_level }}’
The Outcome
This setup worked perfectly! Now, adjusting the volume on the TV’s card automatically syncs with the DLNA device. It’s a small tweak, but it makes a big difference in user experience.
Tips for Others
  • Test Thoroughly: Always test your automations to ensure they work as expected without causing unintended behavior.
  • Consider Delays: If there’s a noticeable delay, you might want to add a small delay in the automation to prevent rapid, conflicting updates.
  • Documentation: Keep your automations well-documented so you can easily revisit or modify them later.
This project was a great learning experience. It taught me how to leverage Home Assistant’s flexibility to create custom solutions that fit my specific needs. If you’re looking to integrate multiple devices seamlessly, I highly recommend exploring automations—they’re a powerful tool in any smart home setup!
Happy automating everyone! Let me know if you have any questions or tips to share!
