HTML Color Picker for Aqara Light Products
Adding an HTML color picker for Aqara smart bulbs and light strips would significantly improve user control and consistency when configuring multiple devices. The picker should support hex codes and RGB input allowing users to select precise colors and immediately apply them to one or multiple devices. When two or more devices are selected, the UI should make it easy to match colors across devices (for example, by applying the same hex/RGB value to all selected devices or offering a “sync color” option).
Benefits:
  • Precise color selection using hex or RGB values.
  • Faster, more reliable color matching across multiple devices.
100 percent agreed, when trying to select on the current system it’s hit and miss to select the correct colour value.
Hello @raf_u
Thank you for your suggestion for improving the functionality, the suggestion will be considered by the team.
@aqarateam
I agree.
