Hub M100 range in a residential house
I have a hub m100 which is plugged in under my stairs. I have a roller driver e1 in my living room and two curtain drivers in my other living room.
I want to install roller shade drivers for my upstairs bedrooms. Is it best to get another hub for upstairs to avoid any signal issues?
@smidscott Great question — this is exactly the kind of real-world setup scenario that comes up often with multi-story homes.
Based on the M100’s specs, the recommended distance between hub and sub-devices is up to 10 meters with no more than two concrete walls in between in typical residential environments. Since your hub is tucked under the stairs (central but enclosed) and you’re looking at upstairs bedrooms, you’re likely pushing past that threshold — especially with floors/ceilings adding to the wall count.
A few things to consider before grabbing a second hub:
  • Zigbee mesh to the rescue — If you have any mains-powered Zigbee devices between floors (smart plugs, switches, or even your existing curtain/roller drivers if they’re Zigbee-based), they’ll act as repeaters and can extend your network organically. The M100 supports Zigbee mesh/repeater functionality, so a well-placed device on the landing or hallway could bridge the gap without extra hardware.
  • Thread devices — If your new roller shade drivers are Thread-enabled, the M100 also functions as a Thread Border Router and mesh extender, which self-heals and extends through compatible devices.
  • USB-A flexibility — The M100’s USB-A power design makes it easy to relocate or add a second unit. A power strip or adapter upstairs is all you’d need.
My take: Try the bedroom drivers with your current hub first, especially if you can strengthen the mesh path. If you get laggy responses or dropouts, a second M100 upstairs is a clean, cost-effective fix given its price point. The local automation support also means either hub keeps things fast even if internet hiccups.
What protocol are your new roller shade drivers — Zigbee or Thread? That might tip the decision.
I was under the impression that the Aqara roller shade drivers were not thread enabled. Is that no the case?
@smidscott You’re absolutely right to double-check that! The Aqara Roller Shade Driver E1 is indeed Zigbee 3.0 only, not Thread-enabled. So the Thread discussion in my previous reply doesn’t apply here — my mistake for tossing that into the mix.
Since your upstairs drivers will be pure Zigbee, the mesh strategy becomes even more relevant. Your existing Roller Shade Driver E1 and curtain drivers downstairs are also Zigbee-based, so if any are mains-powered, they’ll help build out the mesh. Battery-powered devices won’t repeat, though.
With Zigbee, the “two concrete walls” rule of thumb still stands. A floor/ceiling assembly often behaves like a wall (or more) depending on construction. If your under-stairs hub has a clear Zigbee path through repeating devices on the stairwell or landing, you might be fine. If not, a second hub upstairs is the reliable fallback.
Worth testing with one driver first before committing to extra hardware — Zigbee mesh can surprise you, but it’s also not worth fighting if the topology’s against you.
Well , always difficult to say ! We don’t know if your house is more concrete or a wooden house! Concrete is mostly bad for signal! But I have a M3 placed central in my house and don’t have any problems! I would recommend first buy the curtain driver and check signal! If there’s any problems you still can get a m100 or M3 :muscle:
