Hub M3 Doorbell Sound Problem
Hello everyone. I would like to know if anyone has the same problem. I have an Aqara Hub M3 with a door sensor connected. Everything works with an automation that as soon as the door is opened the hub emits the doorbell sound. The problem is the following: as soon as the door opens the sound starts but stops after a second and then starts again from the beginning completing the sound correctly. What could it depend on? I have had this problem for about a month.
Thanks.
Please try turning down the volume of the playback to see if the same issue can still be reproduced.
Actually Volume is set to 68.
