Hello everyone, I’m hoping someone can help me troubleshoot an issue I’m having with my Hue bulbs. I’ve set up a rule to make them blink in a specific color when one of my door sensors detects an open gate. However, the blinking feature isn’t working as intended, and I’m a bit stuck on figuring out why.I’ve based my setup on a previous solution I found online, but I must be missing something. Here’s what I’ve done: I created a rule that triggers when the door sensor detects an open gate. The rule is supposed to make the Hue bulb blink in a warning color every second. I’ve also set up a second rule to stop the blinking once the door is closed again.The bulb does change color when the door opens, but instead of blinking, it just stays on the warning color. I’ve checked the logs, and it seems there’s an error related to invoking a method, which I’m not quite sure how to fix. I’ve tried adjusting the timer and the way the bulb is addressed, but nothing’s worked so far.I’m really hoping to get this working because it would add an extra layer of security to my home. If anyone has experience with similar setups or knows where I might be going wrong, I’d be incredibly grateful for your advice. Let me know if you need more details or specific parts of the code to help me out!Thanks in advance for your time and assistance. I’m looking forward to hearing from you!
