Humidity Sensor Issues and Solutions
Hey everyone, I wanted to share my experience with the Xiaomi Humidity and Temperature sensor. I recently noticed some strange readings—like a 654% humidity spike! At first, I thought it was a hardware issue, so I tried replacing the battery, but the problem persisted. After some research, I discovered that this might be a common issue with these sensors, especially in environments with high electromagnetic interference or poor ventilation.
I decided to try a different approach. I started by checking the placement of the sensor. I moved it to a more stable area with better airflow and away from any potential sources of interference. Surprisingly, the readings became more accurate. However, the spikes occasionally still occurred.
Then, I stumbled upon a solution involving adding a small capacitor to the sensor’s circuit. This helps stabilize the signal and reduces false readings. I was a bit hesitant to modify the sensor, but after some careful research, I found a safe way to install the capacitor without damaging the device. The results were amazing—the false readings decreased significantly!
I also found a community workaround where users adjust the sensor’s settings through their smart home platform to filter out extreme readings. This method, combined with the capacitor fix, has been working wonders for me.
If anyone else is struggling with similar issues, I highly recommend checking the sensor’s placement, considering minor hardware adjustments, or exploring software-based solutions. It’s been a learning experience, and I’m glad I could figure it out without replacing the sensor entirely. Happy tinkering! :rocket:
