Hey everyone, I wanted to share my experience setting up automation with the Ikea Tradfri 5-button remote control. I’ve been trying to get this to work for a while now, and I thought I’d document my journey in case anyone else is struggling with the same issue.
The Problem:
After pairing the Tradfri remote with my Zigbee controller, I noticed that while the device was recognized, the automation I set up wasn’t triggering as expected. Pressing the buttons would show activity in the UI, but the intended actions, like turning on lights, wouldn’t execute. This was pretty frustrating because the remote seemed to be working on the surface level, but the automation layer wasn’t responding.
The Journey to the Solution:
I started by checking the automation configuration. I had set up a trigger based on the remote button presses, but it wasn’t firing. I tried different approaches, including adjusting the trigger conditions and verifying the device ID. Nothing worked initially.
Then, I stumbled upon a crucial piece of information: automations defined in separate files might not work as expected if they’re not structured correctly. I had split my automations into different files for organization, but it turns out that the main automations.yaml file needs to be properly configured to recognize these separate files.
The Fix:
After some research, I realized that the issue wasn’t with the remote itself but with how the automations were structured. I reorganized my automation files and made sure all triggers and actions were correctly referenced. Here’s a simplified version of what worked for me:
yaml
- id: ‘0a8d783d-17be-4b3b-8c35-553daf1a1c32’
alias: Living Room Lights
description: ‘Controls the living room lights using the Tradfri remote’
trigger:- platform: device
device_id: ‘your_device_id’
type: remote_button_short_press
subtype: turn_on
action: - service: light.turn_on
entity_id: light.living_room_lights
- platform: device
Key Takeaways:
- File Structure: Ensure your automation files are properly nested and referenced in the main
automations.yamlfile. - Device IDs: Double-check that the
device_idin your automation matches the one assigned to your Tradfri remote. - Trigger Conditions: Be specific with your trigger conditions. The
subtypeparameter is crucial for distinguishing between different button presses.
Final Thoughts:
It’s been a bit of a rollercoaster, but I’m happy to say that my Tradfri remote is now fully integrated into my smart home setup. This experience taught me the importance of thorough configuration and the value of community resources when troubleshooting.
If anyone has further questions or needs help setting up their own Tradfri remote automation, feel free to reach out! Happy automating! ![]()
