Hi everyone, I wanted to share my experience with installing exterior cameras using non-powered Cat6 cable. I recently upgraded my doorbell setup to include an ADC branded exterior camera, and I thought I’d document the process in case it helps someone else.
The Setup:
I have a non-powered Cat6 cable running through my attic. My plan was to cut this cable and terminate both ends, then connect it to a POE switch along with my internet feed and the camera. The goal was to power the camera without needing a separate power source.
Challenges:
At first, I was a bit unsure about whether the POE switch would add power to the existing Cat6 cable without causing any damage. I did some research and reached out to the community, and it turns out that using a POE switch is a solid solution. It not only powers the camera but also ensures that the network remains stable.
Choosing the Right Switch:
I ended up going with a TP-Link POE switch, and it’s been working perfectly. The switch handles the power injection seamlessly, and I haven’t encountered any issues with signal strength or data transfer. I’d recommend this brand to anyone looking for a reliable POE solution.
Camera Configuration:
One thing I learned is that it’s crucial to set a static IP address for the camera. This prevents any potential connectivity issues down the line, especially if the camera were to reboot or if there’s a network fluctuation. I used my router’s settings to reserve an IP address for the camera’s MAC address, which made the process much smoother.
Testing and Live Monitoring:
After setting everything up, I tested the live feed and was relieved to see that the video quality was excellent. The camera’s夜视功能 also worked perfectly, which was a big priority for me.
Future Plans:
Looking ahead, I’m excited about the new two-way cameras from ADC that are supposed to come out soon. I can’t wait to upgrade my system even further with those. In the meantime, my current setup has given me peace of mind knowing that my property is well-monitored.
Tips for Others:
If you’re considering a similar setup, here are a few tips:
- Plan Your Cabling: Make sure your Cat6 cable runs are as direct as possible to minimize signal loss.
- Invest in Quality Components: A good POE switch and reliable cables are worth the investment.
- Static IP for Cameras: This small step can save you a lot of headaches later on.
I’d love to hear from others who’ve tackled similar projects. What challenges did you face, and how did you overcome them? Happy tinkering everyone!
