Installing Home Assistant on Rock 4C+ - Challenges and Solutions
Hi everyone, I’ve recently embarked on my first project using the Radxa Rock 4C+. After successfully installing Debian 11 via an SD card, my next step was to set up Home Assistant. I followed the guide from Install Home Assistant on Debian Linux, and the Docker installation went smoothly. However, I encountered an issue with the OS-Agent from GitHub (Releases · home-assistant/os-agent · GitHub). Despite trying several versions, I consistently received the error message: ‘package architecture does not match system’. I’m wondering if there’s a workaround for this setup since I couldn’t find a definitive solution in the forums I visited. If anyone has faced a similar issue or has any insights, I’d greatly appreciate your help! Thanks in advance for your support and expertise.
