Integrating the Anker Solix Solarbank E1600 into Home Assistant has been an exciting journey! While there isn’t a native integration yet, I’ve managed to get it working using MQTT and some custom scripts. Here’s how I did it and some tips for anyone looking to do the same.
The Challenge
When I first got my Anker Solix Solarbank, I was eager to monitor and control it directly from Home Assistant. However, the lack of a built-in API or integration was a bit daunting. After some research, I discovered a few community-driven projects that made this possible.
The Solution
I decided to use the solix2mqtt tool, which periodically polls the Solarbank’s API and publishes the data to an MQTT broker. From there, I set up custom sensors in Home Assistant to display the Solarbank’s status, including battery level, charging/discharging status, and power usage.
Steps I Took
- Installed MQTT Broker: I set up Mosquitto on my Raspberry Pi to handle MQTT messages.
- Configured solix2mqtt: I installed the tool and configured it to connect to my Solarbank and MQTT broker.
- Created Custom Sensors: In Home Assistant, I added template sensors to display the data from MQTT topics.
- Automation Setup: I created automations to adjust the Solarbank’s discharge settings based on solar forecast data.
Tips for Others
- Firmware Updates: Ensure your Solarbank is running the latest firmware for optimal performance.
- Monitoring Tools: Use tools like MQTT.fx to debug and ensure data is being published correctly.
- Community Resources: Check out the solix2mqtt GitHub and AnkerSolixE1600-APIServices for additional insights and support.
Conclusion
While integrating the Solarbank required some effort, the result is a seamless integration that enhances my smart home setup. I’m now able to monitor and manage my energy usage more effectively, which is incredibly satisfying. If you’re considering this setup, I highly recommend exploring these tools and scripts—they’ve been a game-changer for me!
Happy integrating!
