I’ve been exploring the integration of my Arlo cameras into Home Assistant without relying on the cloud, and I must say, it’s been a fascinating journey!
While I initially thought it might be a bit tricky, the process turned out to be more straightforward than I anticipated. I stumbled upon some excellent resources and guides within this community that made everything fall into place. ![]()
One thing I found particularly helpful was discovering how to set up the cameras locally, which not only reduces dependency on external services but also enhances privacy. I’ve been using the Arlo cameras alongside my existing Shelly devices, and it’s wonderful to see everything working seamlessly together. ![]()
However, I did encounter a small hiccup with the sensor statuses not aligning properly in the app. At first, it was a bit confusing, but after a bit of tweaking and referring back to the documentation, I managed to get everything sorted out. It’s amazing how a minor adjustment can make such a big difference! ![]()
If anyone else is looking to integrate their Arlo cameras without the cloud, I’d highly recommend starting with the official Home Assistant documentation and then supplementing it with the tips shared here. The sense of accomplishment after setting it all up is truly rewarding. ![]()
Looking forward to hearing about others’ experiences and any additional tips they might have! Let’s keep the sharing going! ![]()
