I’ve been on a journey to integrate my August Smart Lock Pro with both my Abode security system and Home Assistant, and I wanted to share my experience in case it helps anyone else looking to do something similar. Spoiler alert: It works beautifully, but there’s a bit of setup involved!
First, I’ll start by saying that I’ve always been a fan of August locks for their sleek design and reliability. Pairing it with Abode was a no-brainer since I already rely on Abode for my home security. The challenge came in wanting to also integrate it with Home Assistant for local control via HomeKit. I knew it would be a bit of a puzzle, but I was determined to crack it.
Here’s what I did:
Abode Integration: I started by pairing the August lock with my Abode Iota system over Z-Wave. This was straightforward using the Abode app. The lock showed up immediately, and I could arm/disarm my system as usual. The best part? It all works seamlessly without any additional configuration.
Home Assistant Setup: Next came the Home Assistant part. I knew I needed to use the HomeKit Controller integration to get local control. After some research, I found that the August Smart Lock Pro does indeed communicate over Bluetooth with HomeKit. The key was ensuring that the HomeKit Controller was properly configured in Home Assistant.
The Magic Happens: Once everything was set up, I could control the lock both through Abode and Home Assistant. It’s amazing how both systems coexist without interfering with each other. I can arm my Abode system normally, and still have full control of the lock via Home Assistant.
A few tips for anyone attempting this:
- Make sure your August lock is fully updated before starting.
- Double-check your Z-Wave and Bluetooth connections.
- Take it one step at a time – there’s no need to rush.
I’m thrilled with how everything came together. It’s the best of both worlds – the security of Abode and the convenience of Home Assistant, all while keeping my August lock fully functional. If you’re looking to do something similar, give it a shot – you won’t regret it!
Happy automating! ![]()
