Integrating Buderus Logamax Plus GB172 with Homematic IP
Hi everyone! I’m new to the smart home world and have recently started exploring Homematic IP. I’ve always been impressed by its comprehensive coverage for home automation, so I decided to give it a try. My first project is to smarten up my floor heating system, and I’ve ordered the necessary components, which I believe should work well together. * Smart Home Zentrale CCU3 with AIO CREATOR NEO License [link] * Homematic IP Access Point HMIP-HAP [link] * Homematic IP Floor Heating Actuator – 12-fach, motorisch, HmIP-FALMOT-C12 [link] * Homematic IP Actuator – motorisch for Floor Heating, HmIP-VDMOT, incl. Valve Adapter VA80 [link] * Homematic IP radiator thermostat HMIP-eTRV-2 [link] * Homematic IP wall thermostat HMIP-WTH-2 with humidity sensor [link] Now, to my questions: I have a Buderus Logamax Plus GB172 boiler in the basement, currently controlled by the Logamatic RC310. * Is it possible to integrate this into the Homematic IP system? * If not, could this cause issues with the floor heating? For example, if all motors shut off (temperature in all rooms reached) but the pump continues to run because it doesn’t know to stop. I hope you can understand my concerns. Let me know if you need more details. Thanks in advance for your help!
