I’ve recently been diving into integrating my Daikin AC system with my Zigbee2MQTT setup, and I must say, it’s been a fascinating journey! ![]()
While I’ve had some bumps along the way, the results have been well worth the effort. Let me share a bit about my experience and some tips I’ve picked up along the way.First off, I stumbled upon this fantastic integration for the Daikin DTA116A621 adapter, which has made configuring my AC a breeze compared to the older Modbus method. The GitHub repositories for both the Home Assistant component and the SDK have been invaluable resources. I’m truly grateful to the developers for making this possible!Now, onto the Zigbee2MQTT setup. I’ve found that while it offers a sleek interface and robust control options, setting up automations can be a bit tricky. My initial approach involved using HA’s built-in automation tool to capture device IDs, which I then moved to my own YAML file for cleaner organization. However, I’ve since discovered a more streamlined method by leveraging MQTT events directly, which has significantly simplified my workflow.One thing I’d love to explore further is creating more dynamic automations that adapt to real-time conditions. For example, I’d love to have my AC adjust its temperature based on the outdoor weather or even my schedule. If anyone has tips or examples of such setups, I’d be thrilled to hear about them!Another aspect I’ve been experimenting with is integrating multiple devices from different brands into a cohesive system. It’s been a great way to expand my smart home ecosystem while maintaining consistency. I’d love to hear how others are managing similar setups and what tools or techniques they find most effective.In closing, I’d like to share a quick tip: when troubleshooting device integrations, always check your logs for any hidden errors or warnings. They can often point you in the right direction much faster than you’d expect. And if all else fails, don’t hesitate to reach out to the community—there’s a wealth of knowledge and support out there!Happy tinkering, everyone! ![]()
