Integrating ESP32 Camera Module with Home Assistant – Success Story!
Hey everyone! I wanted to share my recent success with integrating an ESP32 camera module into Home Assistant. For those who might be curious or facing similar challenges, here’s my journey and how I made it work!
I purchased this ESP32 camera module from AliExpress, specifically the one with the OV5640 sensor. At first glance, it seemed a bit daunting because I wasn’t entirely sure about the board’s specifications or how to get it working with ESPHome. But I decided to give it a shot!
The Challenge
The main issue I encountered was figuring out how to set up the camera as a web server within Home Assistant. I came across some forums where people mentioned similar setups, but the information was scattered, and I couldn’t find a clear step-by-step guide.
The Solution
After some research and trial and error, I realized that the key was to use ESPHome’s built-in web server capabilities. Here’s a simplified version of what I did:
  1. Identify the Board: I reached out to the seller and confirmed that the module uses an ESP32-WROOM chip. Knowing this helped me configure the right settings in ESPHome.
  2. Setup the Camera: I used the camera platform in ESPHome to define the OV5640 sensor. Here’s a snippet of my configuration:
    yaml
    sensor:
  • platform: camera
    jpeg_url: “http://{{ip}}/camera”
    scan_interval: 5s
  1. Expose the Camera Feed: I configured the ESP32 to serve the camera feed over HTTP. This involved setting up a simple web server within the ESP32 firmware.
  2. Integration with Home Assistant: Once the camera was serving its feed, I added it to Home Assistant as a generic camera entity. This allowed me to view the feed directly within the Home Assistant UI!
The Result
After a few tweaks and restarts, it worked perfectly! I can now access the camera feed from Home Assistant, and it’s integrated seamlessly into my smart home setup. The best part is that I can control it remotely and even set up automations based on the camera’s input!
Tips for Others
If you’re looking to integrate a similar camera module:
  • Start Small: Begin by testing the camera feed independently before integrating it into Home Assistant.
  • Use the Right Tools: Tools like Visual Studio Code and the ESPHome dashboard are invaluable for debugging and configuring your setup.
  • Community Support: Don’t hesitate to reach out to forums or communities like this one. The collective knowledge here is incredible!
I’m thrilled with how this turned out and can’t wait to explore more possibilities with my ESP32 camera module. If anyone has questions or needs help with a similar project, feel free to reach out! :blush:
