I recently set up an ESPHome camera and successfully integrated it with MotionEye, and I wanted to share my experience with the community. ![]()
Initially, I faced the challenge of ensuring the camera feed remained stable. I used the URL http://HOMEASSISTANTIP:8123/api/camera_proxy_stream/camera.esp_camera_1?token=SHORTLIVETOKEN to connect to MotionEye. However, I noticed that the feed would stop once the token expired, which was a bit frustrating. After some research, I discovered that generating a long-lived token was the solution, but I encountered a 401 Unauthorized error. ![]()
After some troubleshooting, I realized that the issue was with the token generation process. I reached out to the community for advice and found that using a different method to generate the token resolved the problem. Now, my camera feed stays stable, and I can monitor my space seamlessly! ![]()
This experience taught me the importance of community support and the value of persistence when dealing with technical challenges. If anyone else is working on integrating ESPHome cameras with MotionEye, feel free to reach out—I’d be happy to help! ![]()
#ESPHome #MotionEye #HomeSecurity
