Integrating Fibaro and Govee for Seamless Smart Home Automation
I’ve been on a journey to create a seamless smart home setup, and I’d love to share my experiences and tips with the community. My goal was to integrate multiple brands, including Fibaro and Govee, to create a cohesive system that enhances my daily life. Here’s how I approached it and what I’ve learned along the way.
Starting with Fibaro Dimmers
One of the first devices I integrated was the Fibaro FGD-211 dimmer. I wanted to use it as a scene controller under UI7, but initially, I faced some challenges since PLEG wasn’t fully compatible. After some research and experimentation, I found a workaround by modifying the device options and using custom Luup files. This allowed me to trigger scenes using the dimmer’s S1 and S2 buttons, which was a huge win!
To achieve this, I:
  • Uploaded a custom Luup file to add scene activation triggers.
  • Adjusted device options to ensure the dimmer correctly identifies scene IDs.
  • Added a small script to reset the LastSceneID variable after each scene activation, ensuring smooth consecutive scene triggers.
This setup has been working beautifully, and it’s been a joy to customize scenes that fit my daily routines.
Exploring Govee Lights
Another highlight of my setup has been incorporating Govee RGBWW Smart BR30 Light Bulbs. These bulbs have exceeded my expectations in terms of brightness, color accuracy, and ease of use. They integrate seamlessly with my smart home ecosystem, and the ability to control them via voice or app is a game-changer.
I’ve also been impressed by Govee’s customer support and the variety of products they offer. If you’re looking to upgrade your lighting, I highly recommend exploring their range!
Challenges and Solutions
Of course, the journey hasn’t been without its bumps. One issue I encountered was with a Fibaro thermostat that occasionally performs calibration runs during the early hours, which can be noisy. After some digging, I discovered that adjusting the auto-calibration time wasn’t straightforward, but I found a workaround by using third-party apps to monitor and manage the calibration schedule.
Another challenge was ensuring consistent connectivity across all devices. I learned the importance of a robust router and proper network configuration. If you’re setting up a new router, I recommend checking if your devices support features like WPA3 or Multi-AP roaming to ensure seamless connectivity.
Integrating multiple brands into a single smart home system can be complex, but with patience and a willingness to experiment, it’s incredibly rewarding. The key takeaway for me has been to start small, test each component thoroughly, and gradually expand your setup.
If you’re considering integrating Fibaro or Govee devices, I’d love to hear about your experiences or any questions you have! Let’s continue to learn and grow together in creating smarter, more connected homes.
Cheers,
