Hey everyone, I wanted to share my recent experience integrating fingerprint sensors into my Home Assistant setup. It’s been a journey, but the end result is fantastic! ![]()
I came across a fingerprint sensor that uses MQTT for communication and decided to give it a try. The setup involved connecting an ESP8266 board (Wemos D1 Mini) to the sensor and then linking it to Home Assistant. The process was a bit daunting at first, but with some research and troubleshooting, it all fell into place.
One of the challenges I faced was ensuring the sensor could enroll and delete fingerprints without needing to reprogram the device each time. I found that using MQTT to handle these commands made the process much smoother. The sensor can now store up to 127 fingerprints, which is more than enough for my needs!
I also wanted to document the entire process to help others who might be interested in doing the same. The guide covers everything from hardware setup to configuring the MQTT integration in Home Assistant. It’s been great to see the community’s positive response and knowing that my documentation might save someone else time.
This project has really enhanced my smart home security. Being able to control my home systems with just a fingerprint is not only convenient but also adds an extra layer of security. I’m thrilled with how it turned out and highly recommend exploring fingerprint sensors if you’re looking to upgrade your home automation setup.
If anyone has questions or needs help with similar projects, feel free to reach out! Happy automating! ![]()
