Hey everyone! I wanted to share my recent experience integrating my new Govee LED strips with my existing Philips Hue setup. It’s been a fantastic journey, and I thought I’d walk through how I made it work seamlessly. ![]()
First off, I’ve always been a fan of Philips Hue for their reliability and smooth integration with smart home ecosystems. When I decided to add some Govee LED strips to my living room, I was a bit nervous about compatibility, but I’m happy to say it worked out perfectly! ![]()
Here’s what I did:
Setup and Configuration: I started by ensuring both the Govee and Philips Hue devices were properly connected to my SmartThings hub. The Govee strips were a breeze to set up using the Matter protocol, and the Hue lamps were already integrated, so that part was straightforward.
Scene Creation: I wanted the Govee strips to mirror the color changes of my Philips Hue lamps. Using SmartThings, I created a routine that detects when a specific Hue lamp turns on and triggers the Govee strips to match the color. It’s been working like a charm!
Tips for Others: If you’re planning something similar, I’d recommend checking the device history in SmartThings to ensure both devices are communicating correctly. Also, make sure your routines are set up with the right inputs and outputs—this helps avoid any hiccups.
Unexpected Benefits: One thing I wasn’t expecting was how much more dynamic my lighting setup became. The combination of Hue’s precision and Govee’s vibrant colors adds a whole new dimension to my home ambiance.
I’m really happy with how this integration turned out, and I hope this helps anyone else looking to mix brands in their smart home setup. Let me know if you have any questions or if you’ve tried something similar! ![]()
