Hey everyone, I’ve been diving into the world of MQTT and integrating my Growatt inverter into Home Assistant. It’s been a bit of a learning curve, but I thought I’d share my experience in case anyone else is looking to do something similar!
So, first things first, I wanted to monitor my inverter’s performance in real-time. I knew MQTT was the way to go, but I wasn’t entirely sure how to set it up. After some research, I discovered that my inverter supports MQTT out of the box, which was a relief!
I started by configuring the MQTT settings on my inverter. I had to make sure the broker details matched my Mosquitto setup on the network. Once that was done, I could see the inverter connecting to the broker in the logs. But here’s where I hit a snag—I couldn’t get HA to recognize the device!
After some digging, I realized I needed to adjust the discovery settings in HA. I added the necessary configuration to my configuration.yaml file, specifying the MQTT topics and the device details. It took a few restarts and some tweaking, but eventually, HA picked up the inverter!
Now, I have all sorts of data points available—like PV power, inverter status, and even temperature metrics. It’s incredibly satisfying to see all that data flowing into HA and being displayed on my dashboard. I even set up some automations to notify me if the inverter goes offline or if there’s a significant drop in power output.
One thing I’d recommend is to carefully review the MQTT documentation for your specific inverter model. Some models might have slightly different topic structures or require additional configurations. Also, don’t hesitate to reach out to the community if you run into any issues—there are some really helpful folks out there who are more than willing to assist!
Overall, integrating the Growatt inverter with HA via MQTT has been a fantastic project. It’s given me a much better understanding of my solar setup and has added a new layer of functionality to my smart home. If you’re considering something similar, I’d say give it a shot—it’s definitely worth the effort!
Happy tinkering everyone! ![]()
