After struggling with integrating my Hardy Barth cHP2 wallbox into Home Assistant (HA), I’m thrilled to share my success story and some tips that might help others facing similar challenges. Initially, I was overwhelmed by the JSON data provided by the wallbox, unsure how to translate it into usable HA sensors. Here’s how I tackled it:
Understanding the JSON Data
I started by carefully examining the JSON output from the wallbox. It was a treasure trove of information, but deciphering it was no small feat. I focused on key parameters like current limits, phase count, and thermal data, realizing these were crucial for monitoring and control.
Creating Custom Sensors
Using HA’s flexibility, I created custom sensors for each relevant data point. For instance, I set up sensors for grid current limits, phase count, and thermal status. This allowed me to monitor the wallbox’s performance in real-time within HA.
Automation and Integration
Once the sensors were in place, I moved on to automation. I integrated the wallbox with my existing energy monitoring setup, ensuring that charging sessions were tracked alongside my home’s overall energy consumption. This has been invaluable for optimizing my energy usage.
Tips for Others
- Start Small: Begin by integrating one or two key sensors before tackling the entire dataset.
- Leverage HA’s Community: Don’t hesitate to reach out to forums or communities for advice. Someone might have already faced and solved your problem.
- Document Everything: Keep a log of your configurations and findings. It will save you time in the long run and help others who might follow in your footsteps.
Integrating the Hardy Barth wallbox into HA was a rewarding experience. It not only enhanced my home’s automation capabilities but also provided deeper insights into my energy usage. If you’re considering this integration, remember that patience and persistence are key. The payoff is well worth the effort!
Happy automating! ![]()
