Recently, I decided to integrate my Ikea Tradfri Wireless Control Outlet kit with the SmartThings ecosystem. Initially, I was a bit hesitant because I had heard mixed reviews about the compatibility of the Tradfri button with SmartThings. However, after some research and experimentation, I managed to get everything working seamlessly! Here’s how I did it:
First, I paired the outlet with the SmartThings hub by following the standard device addition process in the SmartThings Classic app. Once the outlet was recognized and added, I moved on to pairing the Tradfri button. The key was to reset the button and ensure it was detected by the hub. After a few attempts, it worked perfectly!
Now, the Tradfri button appears as a main device with two child devices in the SmartThings app. I found that creating automations using the ‘Smart Lighting’ feature was the most effective way to utilize the button. For example, I set up a rule where pressing the top button toggles my kitchen lights, and holding the bottom button adjusts the patio lights. It’s incredibly satisfying to see how responsive the setup is!
One thing to note is that while the Tradfri button isn’t natively supported for advanced actions, the workaround using automations works exceptionally well. I also appreciate the design of the Tradfri button—the textured sides make it easy to use in the dark, and the strong magnet keeps it securely attached to any metal surface.
Overall, this integration has been a fantastic addition to my smart home setup. It’s affordable, reliable, and adds a touch of elegance to my daily routines. I highly recommend it to anyone looking to enhance their SmartThings ecosystem with a versatile control solution.
